Need Specs on Alpine Bass ZR 10"
Simone_alyce
Hi basically everything is said in the title.
I have all the specs on the rest of my system but no matter where i look i cant find anything on the ZR's, probably cuz theyre too old or something.
If anyone can help me it would be great. Thanx //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
These are the specs from Alpine for the SWR-254E:
Power handling : 300rms/1000peak
Imp. Nom. 4ohms
DC Res. 4 ohms
Fs - 34 hz
Vas - 37L/1.31 cf
Qms - 6.10
Qes - 0.34
Qts - 0.32
Xmax (linear)- 4.0mm
Xmax (peak) - 16.0mm
Diaphram material - Epoxy coated non-pressed pulp
Cone area - 356 sq. cm./55.2 sq. in.
Rubber surround, strontium ferrite magnet (52 oz.), die-cast frame
3" VC
Surface mounting depth 118mm/4-5/8"
Bottom mounting depth 134mm/5-1/4"
Cutout diameter 230mm/9-1/16"
Driver displacement 2.7L/.10cf (top mount) 3.6L/.13cf (bottom mount)
Driver weight 5.6kg/12lb. 5oz.
I also have the list of Alpine recommended sealed, ported and bandpass enclosures depending on the vehicle size.
Simone_alyce
Simone_alyce
Fawkner, Vic
Vermithrax
