Need specs for L5 12inch Kicker Speaker Box
kdogg
14
USA
Hi I need some suggestions for a speaker box. I have a single L5 12inch Kicker Solo-Beric sub woofer. The box I currently have is taking up too much room in my ride. I trying to find the spec's to build a Street/Bass box. This is one of the box's that Kicker provides the spec's on building. Its the mid range vented box. I got the spec's from Kicker to build the big one, but I'm finding it leave me with no room. I would like to build a new one using the spec's of the mid range street bass box.
Btw, when I say mid range, I mean middle of the size ranges of the 3 box's Kicker recommends building =)
Anyway I have tried to repeated get in touch with kicker to get the specs on that box and havent been able to get ahold of them. They dont return my emails or phonecalls.
Does anyone have the specs for this box or know where I might locate them?
Any help would be great.
Thanks.
Originally posted by Jmac You definitely won't be happy with any of Kicker's recommended boxes ...
Jmac is right. From what he has told me then you wont be happy with the recommended boxes. Besides he is the "Subwoofer Box God" so you must believe in him if you want great sound //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Well I built the big fill sized box that Kicker recommended for the single L5 and it POUNDS!!!!
Has to be one of the hardest hitting setups based on a single 12 I've ever heard. I don't see why the mid range sized box would be any worse.
Do you have any sugguestions or spec's for anything better Jmac?
hey jmac
can you design a single ported box for one L7 12" ?
i am running it at 4 ohms on the jbl1200.1
i want is as small as possible...maybe even stuffing it with dacron or polyfill
gimme the volume etc...so i can get my technician to make
he is desinging one but i sure yours will be better
i want it loud and clean //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
thanks
Originally posted by Jmac Just need the dimensions of your trunk. By the way, polyfill won't help in a ported box //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
ok thanks i'm gonna measure it now
hey jmac....these are the max dimensions that i can work with....the trunk is relatively big...but i need the space
its a mitsubishi galant 2000 model
specs :
23" X 14" x 12"
or
30" X 16" X 12"
hope u can help me
my tech said kicker's recommendations wont sound good...it wont play low bass properly
what you think ?
thanks //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
i am using the kicker x3i crossover...with a selectable 25 Hz subsonic filter 24db/octave
the second set of specs i gave....is the maximium dimensions....the depth i gave as 12"...is negligable
do u have msn ?
there is alot of space....i woul say about 25-30 inches...i didnt really measure it
the shallower you can design the box...the better
my tech said i should point the sub and the port facing the inside of the car
what do you think ?
thanks again
Originally posted by Jmac Construction Material = .75" MDF
Box Height = 14"
Box Width = 24"
Box Depth = 12"
Number of Ports = 1 (Slot)
Diameter of Port = 12.5" x 1"
Length of Port = 24"
Port Area = 12.5 square inches
Box Volume = 1.329 ft^3
Box Tuning = 30.642 Hz
WinISD Estimated Peak SPL = 62.4 Hz
WinISD Estimated 3 dB Down Point = 45 Hz
WinISD Estimated Peak Port Velocity (600 watts) = 30.7 m/s @ 25 Hz
hey thanks alot ! //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
this would accomodate the L7 grille rite ?
how this box gonna sound...in simple terms ? //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
also...would it handle the power of the jbl at half load ?
oh man...i have the L7
i guess the title of the thread got u confused
u think u can work some magic for me on the L7 ?
thankssss //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
kdogg
kdogg
USA
v8s10
