Need Some Suggestions!
Thats what I thought. So I should Drill a hole in the trunk (Of course look before drilling lol) Drill a small hole in the frame? Bolt in down and caulk the shit out of the hole when done? Do this sound right? How long should the ground cable be? Thanks
ground cable should be as short as u can make it. I grounded it to a hole that my spare tire was held onto (no more spare tire). Of course sand it down completely to get the best possible connection.
Thats what I thought. So I should Drill a hole in the trunk? Thanks
Drill straight into the gas tank & stuff the wire down in that hole...//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
(kidding)
Shortest cable possible, but 2' or 5', not real important. I'd hot glue the whole thing after bolting it up, caulk will work too. Nail polish. spray paint. Or nothing at all.
With Carpet on
Back Flap lifted up (for easy voltage testing)
You can see I grounded it with the grey 1AWG wire, the red one is from the amp.(yes there is a bolt there, I used the electrical tape just for safety, dont want anything accidently falling loose and grounding out.)
Just a random pic
It's a temporary install until I make a frame to hold the battery better. Belive it or not its rather sturdy right now, but im still planning to make it look cleaner/neater.
Actually, seatbelt bolts work as good as any other ground point on your car, since all the metal on your car is a ground plane. I've been using the rear seat belt bolts in my cars for years. Never one problem.
I am uploading some pics I just took. I cannot do mine like that. The bolt that holds my tire in is not statuanary enough. But I have a alternative.
Where the tire goes. Notice how flemsey (SP?) the bracket is.
http://i81.photobucket.com/albums/j202/Dewitt88/P1080030.jpg
Look Closely at the little holes. That is the ground on the other side. Perfect place to drill a hole to run wire through.
http://i81.photobucket.com/albums/j202/Dewitt88/P1080031.jpg
Bottom Of Spare Tire Holder
http://i81.photobucket.com/albums/j202/Dewitt88/P1080032.jpg
Where I think is a good Ground? I can Drill a hole and bolt my wire on the frame where the holes are. Sound ok???
http://i81.photobucket.com/albums/j202/Dewitt88/P1080034.jpg
If this will work I think I will be fine. Only concern is that the ground will be 3-4 Ft long. Will this be ok? Thanks again.
dewitt88
Life Is What You Make It
dewitt88
Starke Fl
dewitt88
