Need some recommendations (NEWB)
Thank you supa c.
My ml has a 115a alternator. Guess I'll have to stick to a less setup, as the 1200.1 draws about 15X amps, and I'm guessing that would cause issues. Still open to suggestions for a setup.
The pg ti's are single coil 4's (most dual coils are sold out), so they can't be wired for a 2 ohm load individually, so it would be irrelevant if I were to run that sub. (If I butcher this stuff, I apologize)
As for the 2 12's, it's like I said, I'm just bouncing ideas around.
As a response to a previous post up there, the Tantrum 1200.1 draws slightly more than 80 amps. I have mine fused at 100 at the distro block, never blown a fuse.
But you're right in thinking that slightly less power will be a lot less taxing on the electrical system.
What do you guys thing about the Rockford Punch series 2. Do these subs have good sound quality? Are they any good or are they just low level subs?
Thanks in advance.
bluevilevo8
bluevilevo8
FL
DragonCub
michigan born
    May 14, 2026
michigan born
    May 14, 2026
