need some personal experiences or insight on re mx subs
Joe562MMA
I was planning on one good 18 inch sub for around 4 500 but I got offered 2 12 inch re mx never been mounted for 500...
What do u guys think I plan on a custom box for either and I have a sundown saz 2500d anp to power the subs I know ill be underpowering them aince there rated at 1500 rms each
My electrical ia ok but gonna add another batterie I have one yellow top an 200+ alternator
2 12s is less cone area then one 18?How does that work..
Area of a circle = pi * r^2 . Still I'd go with the MX's assuming they wire to a good impedence for you, two 4" coils will handle thermal power long term far better than a single 3" coil.
If you're just burping with it you'll probably do better with a single 18
291
Very nice to hear you found what you needed to get your audio system/ect. up to your needs. we appreciate the information provided in this thread...
301
556
Joe562MMA
Joe562MMA
Los Angeles , CA
Quaid_Station
    May 24, 2024
