LosIsATool 5,000+ posts
If you are passive and not bi amp the crossover will pop firstHope they will sound louder than my actual system, I will connect them @190w in 4 ohms. Is that too much for tweeter?
Yes, I will use the passive filters.You will not be sending any of the speakers 190w. Your amp is 65x4 @ 4 and 190x2 @ 4. If you do decide to bridge it to the 190x2 you will have to utilize passive crossovers. The 190 per channel will be split between the the 2 speakers so roughly 95 to each.
As mentioned earlier, you can also look into an outboard crossover as your amp does not seem able to do bandpass. This will allow you to drive the mids and tweeters separately giving you more control over both frequency and power.
A last option would be to find a component set with biampable passives. This would be a compromise between the two.
Reference - B2 audioB2 ref is probably the best out of the bunch, but I think they cost more, too. Which set are you getting? I'd be interested in a review of either the B2 or ESX.
I don't think you'll be disappointed.Reference - B2 audio
I can get ref6.1 here, in Europe for roughly 230 euro.
Same amp, in bridge with included crossovers.Are you going to use the same amp for tweeters? Or do they have a separate amp?
I hope so!I don't think you'll be disappointed.
You might need to dial it back a bit. But like said the tweeter will nowhere near that power maybe 50 watts at most then the most to the mid. If you set the crossover on the amp and deck at 100-120 hertz. The components will take the power better thoHope they will sound louder than my actual system, I will connect them @190w in 4 ohms. Is that too much for tweeter?
Yeah, this is exactly what I want to do. I'll put hpf@100 in my amp because I don't need excessive bass from mids, I need just kick bass.You might need to dial it back a bit. But like said the tweeter will nowhere near that power maybe 50 watts at most then the most to the mid. If you set the crossover on the amp and deck at 100-120 hertz. The components will take the power better tho
HPF at 100Hz at 12db slope may just give you excessive midbass. Start from 120Hz, not many drivers can perform that well that low.Yeah, this is exactly what I want to do. I'll put hpf@100 in my amp because I don't need excessive bass from mids, I need just kick bass.
My deck doesn't have crossovers //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
