need some help with saz1500's and my setup.
if you get a btl 18 get it in dual 1ohm coil.
with dual 1ohm coils wire them up in series for a 2ohm load for strapped 1500ds.
if you go below the 2ohm mark on the 1500ds then you are voiding your warrenty. though you might already be with your 1 1500d on that 15 pending on when you got the amp.
i am in consideration of getting a 15d1 btl as i have 2 1500d's.
are you considering a used 18d2?
if you get it and run them strapped at a load of 1ohm each amp will be seeing a .5ohm load(i believe). iirc not really recommended for daily and you'd better have the electrical for it.
twisztdpunisher
twisztdpunisher
Bakersfield, CA
twisztdpunisher
michigan born
    May 14, 2026
michigan born
    May 14, 2026
