need some 6 1/2
What year and specific model of Accord? What kind of budget are you looking at?
A 4-Channel would be fine and probably the easiest install. If you really wanted you could get two 2-Channels but I don't know why you would. //content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif
ok?...well what is your specific model of your accord and year? that kinda helps a little bit //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif then I'll give some suggestions that I like
did he mean he maybe thought it would be ok to power it with the headunit?
no, he meant that you could run the 2 channel with a 2ohm load on each channel, and power all 4 speakers.(cheapest way, #1- 4 channels are more $$, #2- you need to run a 2nd set of rca's to a 4 channel, unless you like to fade front/rear)
actually i think he ment using two amps, each with two channels //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif kinda the same as a 4 channel amp....
But using one 2 channel amp and hooking both front and rear left speakers to one channel and all the right speakers to another will work too.... its what I'm running at the moment
fastaccord
fastaccord
Tallahassee, Fl
fastaccord
