need sealed box plans for alpine type s
thur5d4yf4n
I want to build a sealed box for my alpine type s but im having trouble finding any dimensions that are close enough to the specs on the type s. i tried using winisd but that didnt really work out. any help is greatly appreciated. the box is going in the rear cab of a ranger xlt so there arent really any restrictions to width/height. here is the sub i have to work with:
http://www.crutchfield.com/S-9jPhFYdiPJ8/cgi-bin/ProdView.asp?g=520&tab=features_and_specs&i=500SWS1243#Tab
thanks in advance //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
Well make a box that is one cubic foot. Which would measure 12x12x12 INTERNALLY. You will need to adjust a bit for the thickness of wood so externally you would have 13.5 instead of 12. Make sense? If you want to get fancy, you can make a wedge shaped box which would have a longer bottom than top and use the 12" as a minimum interior length. So the bottom would be 14" long internally. This would give you just ver 1 cubic foot internal volume AFTER the displacement of the woofer is removed.
thur5d4yf4n
thur5d4yf4n
Glendale, AZ
AK SloPok
michigan born
    May 14, 2026
michigan born
    May 14, 2026
