Driver Properties
Type: Standard one-way driver
Company: Rockford Fosgate Corp.
Comment: P3 Punch Stage 3 series
No. of Drivers = 4
Mounting = Standard
Wiring = Series-Parallel
Dual voice coils = separate
Fs = 27 Hz
Qms = 6.69
Vas = 0.865 cu.ft
Cms = 0.0313 in/lb
Mms = 6.67 oz
Rms = 10.74 lb/s
Xmax = 0.472 in
Sd = 48.05 sq.in
Qes = 1.08
Re = 1.7 ohms
Le = 1.8 mH
Z = 2 ohms
BL = 1.619 lb/A
Pe = 200 watts
Qts = 0.93
Box Properties
Name:
Type: Vented Box
Shape: Prism, square
Vb = 4.927 cu.ft
Fb = 29.06 Hz
QL = 5.869
F3 = 21.95 Hz
Fill = none
No. of Vents = 1
Vent shape = rectangle
Vent ends = one flush
Hv = 12 in
Wv = 5 in
Lv = 35 in
Box outside dimensions: 24 x 36 x 17
Cut list, (you may want to try a different way) and you should double up the baffle:
Box Parts (Square Prism)
1 Top, 1 Bottom: 17 © x 36 (b) in
0.75 (thick) in
1 Front, 1 Back: 22.5 (a) x 34.5 (d) in
0.75 (thick) in
2 Sides: 22.5 (a) x 17 © x 0.75 (thick) in
Vent Parts
1 Top, 1 Bottom: 6.5 (e) x 35 (h) in
0.75 (thick) in
2 Sides: 12 (g) x 35 (h) x 0.75 (thick) in
all in all those subs are not that great ported, you'd be better off getting a sub that likes ported boxes.
