Need Ported Box Plans Please!
Here is my old ported box wih 4 12"s
ok i have the specs from rockford for recomended ported enclosure
i have 4 of these p-3's i want them all in a ported box
here are the specs for one of them in a ported box
H= 14.5 W=22.5 D=10''
recommended cu ft 1.25 (35.40 L)
recommended port 3'' x 7.3''
so i need plans just like the box that was built for those 4 type r's
but only built for my subs
can someone draw up something or give me some dimentions??
thank you
Why not sell all your rockford's and buy 2 12" Fi Q's and put in them in a 4ft^3 NET box tuned to 33hz and sit back and drool?
Instead of trying to fight and get these to fit......With those MAX dimensions with 1/2" taken off each your right at 7 cubic ft......Whats your sub displacement?
Driver Properties
Type: Standard one-way driver
Company: Rockford Fosgate Corp.
Comment: P3 Punch Stage 3 series
No. of Drivers = 4
Mounting = Standard
Wiring = Series-Parallel
Dual voice coils = separate
Fs = 27 Hz
Qms = 6.69
Vas = 0.865 cu.ft
Cms = 0.0313 in/lb
Mms = 6.67 oz
Rms = 10.74 lb/s
Xmax = 0.472 in
Sd = 48.05 sq.in
Qes = 1.08
Re = 1.7 ohms
Le = 1.8 mH
Z = 2 ohms
BL = 1.619 lb/A
Pe = 200 watts
Qts = 0.93
Box Properties
Name:
Type: Vented Box
Shape: Prism, square
Vb = 4.927 cu.ft
Fb = 29.06 Hz
QL = 5.869
F3 = 21.95 Hz
Fill = none
No. of Vents = 1
Vent shape = rectangle
Vent ends = one flush
Hv = 12 in
Wv = 5 in
Lv = 35 in
Box outside dimensions: 24 x 36 x 17
Cut list, (you may want to try a different way) and you should double up the baffle:
Box Parts (Square Prism)
1 Top, 1 Bottom: 17 © x 36 (b) in
0.75 (thick) in
1 Front, 1 Back: 22.5 (a) x 34.5 (d) in
0.75 (thick) in
2 Sides: 22.5 (a) x 17 © x 0.75 (thick) in
Vent Parts
1 Top, 1 Bottom: 6.5 (e) x 35 (h) in
0.75 (thick) in
2 Sides: 12 (g) x 35 (h) x 0.75 (thick) in
all in all those subs are not that great ported, you'd be better off getting a sub that likes ported boxes.
SethPhillips
I'sa Playa
SethPhillips
Northern Utah
SethPhillips
