Need ohm/rms Answer - ASAP
Umm couldn't he run the subs in parallel with 3 D4's that would get you a .7 ohm load and most all decent 1 ohm stable amps will be fine with this. After imp rise you will be above 1 ohm most the time any how.
haha ok, so tell me if im wrong.
3 15" SDC2.5 AUDIOQUE Subs & a KICKER 2500 will require its own battery?
and yes i have the rockford wires, this a good thing?
You will need an extra battery for it because the batter you have in your truck is for the truck!
But for output it will be alot better than the kenwood jbl stuff you were gonna pay 800 for. And getting the quality equipment is worth the extra cash required for the electrical upgrades.
i have the rockford 4AWG install kit.
16 awg speaker wire, 30FT (or) 9.1 meters - "high strand for INCRESED SOUND TRANSFER"
4 AWG power cable, 17 FT (or) 5.2 meters - "high strand for INCRESED CURRENT TRANSFER"
TWISTED PAIR signal cable- 16FT - (or) 4.9 meters - helps reduce noise for ENHANCED SOUND QUALITY"
Maxi FUSE HOLDER
guitarman626
Guitarman626
guitarman626
Lubbock, TX
benchambers80
