Need New Battery or alt??
lionel2
PA
I wanna run another amp..a 4 channel amp with my mono amp...will i need to upgrade my battery or alternator??...i have a 850CC battery just a regular one and a 105A alternator...my mono amp is 1700w...running at 500w rms @ 4 ohm...with 2x30A fuses...my 4 channel..well i have not got yet..pretty sure i will get something like a RF 4004...the new 2006 model...it does 25x4@4 ohm...with 2x20A fuses..what and how do you find out how much current these amp pull?? will the alt and batt i have survive..right now my volts stay at 14.4V...and my batt is just fine..little low...but will get a yellow top if it dies...and alt..will a 140 or 160A be sufficient..thanks..and help will do
I had a 105a on my truck for the longest time. You will be fine off the power you have. If you notice any dimming, try the "big 3" before you get a new battery or alt. Hook it up and reply back on what happens.
it looks like your not running that many watts RMS and 14.4 volts is really good so i would just get a bigger battery like an optima, odyssey, or kenitik.
I checked out all possible batteries to get and optima yellow top is the only one with the GM side posts..i dont wanna have add ons just built right on there..and i can get a yellow top for about 169.99 installed..maybe when i upgrade subs and amps i will get big batts in the back any kind like kinetik...will autozone have 140 or 160A alt for a blazer??
lionel2
lionel2
PA
lionel2
