Running speaker wire with Power???
One thing though, with some installs with RCA directly over/running with PWR, interference is not an issue. You cannot get a direct answer, so I would run everything and take a listen while the carpet is still up, and if you're having problems, then move it, if not then finalize it and be done.
Thanks alot man:D
Thanks alot man:D
I know it is not really any type of an answer, but like I said, soetimes there is inter. and sometimes there isnt.//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
there are some highly respected opinions in the industry that believe pwr/signal interference is a myth, and electromagnetic theory supports it.
It is actually fairly common to run pwr/signal/speaker/remote wires all in the same bundle.
Regarding speaker wire specifically - Magnetic fields are created by current. Speaker wires are much lower current than power wires and the magnetic field they generate is just not strong enough to be a concern.
azngotskills
azngotskills
Dallas, TX
AcidicDreams
