need more output... opinions desired
psych0ticnemes1
Psych0tic Customs
i have an R 15 in 4 cubes tuned to 35 off of 1200 watts... it is loud, but i'm looking for more output off of the same power... I had four 12's so you can see where i would be a bit disappointed. I figure two 15's would do me well...
which 15's though off of 12-1500rms?
Two comp VR's
Other suggestions?
only want to spend 300 or so
I only have 6 cubes to work with ported... but i like the idea of the comp vr's...
Thanks for the advice
back in the days i had two CompVR 12" 2002 series ported, a friend of mine had two Alpine Type R 12" sealed. the CompVRs outperformed the R´s easily with the same power. but you cannot really compare them as the CompVRs were ported :-|
plus the compVRs changed a lot, cosmetically and technically.
i can only tell you the 2002 series with the black cones only needed around 400watts each to get loud, the type R in sealed needed 600+.
perhaps you can give a used DD3515 a try, they have a high sensitivity and will be OK with 1500. i have a 9512 and it is way louder than the two kickers or the Type Rs even it is only one 12". but go with a 15" DD 3500 series they have higher sensitivity than a 12" and you got the space so use it.
DiDan
do another type r......should be more then enough for ya.......a more expensive approach would be 2 15" CVX...but ive only herd 12" not the 15" , so i cant say much exept that the 12" comp vx are loud mofos. i would assume the 15 are the same
psych0ticnemes1
Psych0tic Customs
psych0ticnemes1
Behind You
kotec123
