need midbass for XT25SC50-04
I'm on my phone so just one browser window haha... Finding the link would take some time. http://www.diymobileaudio.com/forum - go to tutorials - look for the thread by npdang about the rationalle why it's just fine to use 8 ohm drivers in a automotive install. Don't forget your amp will play cleaner at the higher impedence.
T
Thank you, I wasn't going to go into it again. But I will post the link you're referring to.
http://www.diymobileaudio.com/forum/showthread.php?t=31
****it you did the hard work for me. Now I'm home... coulda posted link... did it for me //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
T
the xt 25 technically "can" play down to 2k but i wouldn't do it... it started crapping out pretty quickly after passing the 3k mark. Also i would go for the seas p18rnx, they can play really high and will be a good match for the tweet.
You're dealing with a smaller format tweeter. Lower-end woofers will not likely play cleanly high enough to mate with that tweeter. Cheaper softer cones (paper, plastic) will start to roll off too early. Many metal cones will have an early break-up point and get super-nasty above that point. Invest in a decent midwoofer or you will have to replace the XT25 with a large-format tweeter that has a 4" faceplate //content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif
T
I own the Dayton Alums. They definitely play much higher than many 7" mids, but not cleanly. They don't have a nasty breakup like the RS180s, possibly due to the fabric dustcap. Detail was on par with my RE Audio poly cone 6.5s. I'm personally going to pick up a set of the Seas CA18RNX woofers. From what I've read they have solid midbass, extended midrange, and midrange detail that won't get harsh like a metal cone.
T
Peerless HDS Nomex 7" gets my vote.
Nomex cone, cast basket, great low end, excellent midrange, natural roll off somewhere around 4k (mine are crossed at 3.15 though), yes they are 8ohm drivers, but they easily outperform the type X 6.5s they replaced, no questions about it.
The XT25's can easily extend down to match with the Dayton RS's...
Dayton's to ~1.6kHz and XT25's pick up ~2kHz
nG
Ouch, i couldnt listen to those that low-very grainy. I'd opt for the larger driver to play more of the critical midrange in a 2way. Unless both drivers were side by side in array buried deep in the kicks and some eq work. They wouldnt like high volumes very much, neither would the listener.
ent3rdadragon
ent3rdadragon
San Diego, CA
3.5Max6spd
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
