Need helpwith testing out power, fuse to amp.
BigTymerzNB
Hey, I am having trouble getting my amp to power up and was wondering if there is any way to test out to make sure the ground wire is working properly, the power wire is, and the remote wire is. I am not sure which one isn't connected properly, and I have some tool which I can use to test out electricty stuff, but not too sure how to use it, any DETAILED help would be greatly appreciated. Thanks.
Most amps have a light on them that will only turn if both the ground and power are correctlt connected. Make sureyour ground is real snugg to the chassis, alot of amps are real picky about there grounds //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
that sounds good just make sure all paint is scraped away and that the ground wire is as short as posible. if you want to test your ground find an extra battery and ground the amp directly to the battery. the ground you have should be fine if it still don't seem right maybe just try a whole different ground then
BigTymerzNB
BigTymerzNB
New Jersey
maylar
michigan born
    May 14, 2026
michigan born
    May 14, 2026
