need help!!!
David0321
well i recently purchased a zxkicker 650.4 and some infinity kappas 6 1/2 3 way 225w..and the amp cuts off after playing for about 10 or 15 min it gets real hot..anyone might know what my problem is? im running 0 gauge cable..and its wired the right way..i was thinking it was maybe cuz the speakers are 2 ohms? maybe i need some 4 ohms? any help is aprecciated..thanks ppl
You say it's wired correctly but that doesn't say much.
1) Do you have a good sanded and solid ground.
2) Where is your amp mounted, is it mounted upside down?
3) Is the amp 2 ohm stable per channel?* I doubt this!
* If it's not, for the right price I will buy the amp, and suggest you acquire a JL amp which is, or any other amp that is.
Those amps are defiantly 2 ohm stable unless bridged, so like dj said check your grounds. What kind of voltage are you getting at the amp? Is the amp bridged to 2 channel?
i just unbolted one nut from the back seat of my truck (2008 silverado crewcab) and bolted it there...and the amp is just on the floor or (carpet) its not bolted down
^^ ill try that in a bit..and i was talking to one of my friends and he says those speakers are no good cuz there 2 ohms and i think they drop the amp down to 1ohm and it cant pick up all 4 speakers
David0321
David0321
houston tx
David0321
AJ (ACE)
    Jun 28, 2026
