Need help with wiring and installation
Red Rocket
I'm a noob to car audio so forgive my dumb questions. I know this isn't the best set up but most of it was a gift and it's not that bad for a first system I suppose. I have no idea what size wiring and everything else that I need to install the stuff below. It's going into a 1994 Pontiac Bonneville SSEi. Also, will I need more power or am I okay with my current battery?
Subs are:
Model Description...........................BTL10X3 10" Tri-Sub Enclosure
Impedance.....................................4 ohm
Power (W) RMS/Total....................750/1500
Frequency Response....................43Hz - 150Hz
Sens...............................................92.2dB
Dimensions (H x W x D)................ 13 1/4" x 35 1/4" x 14 1/2"
Amp is:
Audiobahn A8002T
RMS Power: 200W x 2
Bridged RMS Power: 800W x 1
THD at Rated RMS Power: 0.02%
Speaker Level Inputs: No
Preamp Outputs: Yes
Built-In Crossovers: HP/LP
Bass Boost: 0-18 dB
Frequency Response: 10-40,000 Hz
Channel Separation: n/a
Signal to Noise Ratio: > 100 dB
Fuse Rating: n/a
looks aite for a first setup mang...you should run it and see if you're getting significant power loss...if you are getting significant power loss then you should do a big 3 or get a new battery...you can run 4 or 8 guages to the amp...
It doesn't matter if it's 4 or 8? Also, any names I should look for/stay away from?
I would run 4 gauge, some people might tell you to run 1/0 gauge, but only do that if you seriously intend on upgrading to larger amps in the future. In my older setup. I ran the A800T pretty good little amp for the price, I ran it at 1.5 ohms for over a year, worked like a champ until the day i unhooked it.
Red Rocket
Red Rocket
Hatfield, PA
Red Rocket
michigan born
    May 14, 2026
michigan born
    May 14, 2026
