need help with picking sub for r5001d
  • 4
500 Watt Class-D Mono Amplifier
The Prime R500-1D is a 500 watt mono amplifier using efficient Class-D circuit topology. This amplifier is capable of running a 2-Ohm load*
You can also set up your subs at 1-OHM. There are quite a few 5-channel amps that will do that, such as the Sundown Audio SAE-1100.5.
52
While we're speculating, why not bump up your volume gain (no pun intended) for just a few dollars more (literally) and go with the 8" versions of...
Also, it depends on the type of wire they installed. Copper will carry a lot for power than aluminum. How much power is your US Acoustic amp...
126
carter62
carter62
bakersfield
audiobaun
