rayray007
I am hoping someone here can help me out. Every time I turn up my radio, the base and volume will sound great for about 5 seconds. The volume starts to fade away as if someone is turning it down to less then half. It is very annoying and nobody has the solution. Ford claims that it is a factory installed protection device so you don't blow your speakers which I understand, but when the volume goes down so much that you can barely hear the vocals or beat, it becomes a major issue.
If anyone has had this problem and came up with a solution (swap out amp or something) please let me know. My Navigator does have the factory DVD system for the rear passengers just in case someone here wanted to know since it may have a role to play in this issue.
Also if anyone does have a 2007 Lincoln Navigator or other Ford product that had this same problem and figured out a solution, please let me know. The Ford dealer is no help at all and keep telling me it is normal but anyone that has owned a Escalade or QX56 can tell you otherwise.
Thanks in advance!
Thanks in advance!
