need help with little red light
i have an audiobahn A6004T, ot was working perfectly for months until now. just outta random theres a blinking red light under the word "protection" and it wont make my speakers work. i tried resetting it but it only works for a second and then it comes back on. while its on the speakers make a thumping noise every 3 seconds. i rehooked all the wires but im still havin problems. and i dont have the instructions.
Poor ground connection?
Blown amp?
Several possibilities considering the very minimal info you've provided us with...
Yeah, probably time for repair. The memphis amps i have worked on will keep pulsating on and off the protect light if some of the output fets are bad. This happens alot with the memphis amps that use the P channel FETs. I personally don't care for them at all... Some people swear by them.. Not sure if you Audiobahn is of the same old design as the memphis D class but sounds like it is doing the same thing.
alright well i got it to work for little while normally but then it went back. it only works at like a tenth of the full volume, any higher it'll crap out again. if it does i gotta reset it. i already disconnected the woofers and hooked them up again... nothing happend.
screaminghooker
screaminghooker
palm beach gardens, FL
screaminghooker
