Need help with design for Sundown X12 v2 @29Hz.
CplCuddles
Certified Meme Warrior
I'm not the one building the box but a local shop is. I want it tuned to 29 hz but the guy said he would have to make the box quite a bit bigger and have to build it in my trunk which would mean $500+.
Vehicle : 2000 Ford Taurus
Location in the vehicle: Trunk
Space available (Length x Width x Height): 45x40x19
Subwoofer make and model: Sundown Audio X12 v2 D2
Subwoofer Size: 12"
Number of Subwoofers: 1
Type of Port (Kerfed, Slot, Aero, etc.): slot
What type of music do you like?: Rap/Decaf (25-35Hz is where I like)
Is your goal SPL or Everyday Music?: Daily
Tuning Freq (Hz): 29. I just want that 25-35hz to do the best. So maybe 29 isnt right.
Volume : Sundown recommends 2.5cuft with 40sqin of port
Sub specs:
X12v2 D2
RE (ohms) 3.80 ohm
FS (Hz) 36.1 hz
Vas (L) 17.1L
Qes 0.44
Qms 4.89
Qts 0.41
Le (mH) 2.41 mH
BL (NA) 25.2
Mms (Gram) 326.2 g
Cms (uM/N) 0.06 mm/N
Sen (1w/1m) 84.4 db
This is the design that the guy made up, but i dont want 32hz tuning.
Ive seen other people online with boxes smaller but tuned lower. What do. Anything else you guys need let me know. Im going to have him build it this tuesday.
I'd tune around 32hz, you'd still play down to the mid 20's easily. Either way I'd find a new box guy, that guy is obviously an idiot. If I'm looking at it right, he's trying to run a single 12 in 4cuft. Give me a minute and I'll hook you up with a design
Sent from my SM-G925T using Tapatalk
Yeah , 4cu for one sub sounds way too big for a single 12". Best box I ever built was 4cu tuned to 32hz in 2 12"s. It is bad to the bone !!!
People didn't like ported boxes because the port noise and needing a bigger box. Therefore, instead of 1-sub in a ported, they would go with...
30
488
857
CplCuddles
CplCuddles
Topeka, KS
mrpep
    Jun 1, 2024
    May 31, 2024
