Need help with box design/calculations
Slappin709
I'm thinking about how to design my next box. It will be for 4 12's. I know the sub choice is disappointing but I'm a high school student with little money, just trying to have fun. I've had a single 10" before but it wasn't enough. The subs will be Dual DS12's, just shitty single 4 ohm standard drivers. I was thinking about 7 cubes(1.75 per sub) at 34hz. The plan is subs up, port back, using a 12" sonotube(~113" port area). It will be going in a late 90's Escort wagon. They will be ran off of a Hifonics Brutus BXI1210D @ 1ohm. I'm having problems trying to calculate the box volume/tuning. I don't understand how to tune regarding including or not including the displacements of the bracing, subs and the port. If I'm looking for 7cubes with a final tuning of 34hz how would I go about getting that? Thanks!
How much are those Duals?
Wow I totallly missed that. I guess i'll decide when the time comes.
Do you know the answer to the box question?
Well, if you get the PG's then the box you want will be a bit big for those. Also you didn't list your maximum dimensions. That's rule #1 when fishing for a box design.
Slappin709
Slappin709
St. John's, NL, Canada
Pr1m3
