need help with amp
  • 4
aaronfelix127
tucson
Hello every one i needed some help. I just bought 2 10" kicker cvrs, they are rated at 400watts rms each at 4 ohms. I found an amplifier that is rated 400watts x 2 channel at 4 ohms does this mean that each chanel is givign out 400 watts each of 200 each? The subs are dual voice coil. Please hekp out
You need a amp that does 1000 at 1 ohm. My wife has the same subs in her blazer , we are selling them , and a hifonics 1000 watt amp. Also selling. But they work good together
You have d2 subs. So you need your power at 2 ohms or .5 ohms both of mine won't give you enough power at 2 ohms. But I do have a couple of new ones that will work . What's your budget ?
Im honestly at 100 left for an amp. I pretty much spent it all on subs
Wow, but anyways there is a powerbass asa1000 that's half ohm stable that you could buy on here. Look in the amp classifieds. Powerbass has solid amps
its 125 shipped
535
While we're speculating, why not bump up your volume gain (no pun intended) for just a few dollars more (literally) and go with the 8" versions of...
937
* The fuse at the start of the cable needs to be equal to or greater than the fuse/load at the end of the run. * The cable needs to be capable of...
No not in this situation.PM sent for proper use of the Y splitters for this situation
34
5K
aaronfelix127
aaronfelix127
tucson
mylows10
Brendon Jenness
    May 8, 2024
    May 8, 2024
