4 channel amp with only one rca output from HU
  • 6
Look for this, its called a Y split. Cheapest route other than buying a new HU. But will you loose front and rear fade.
I probably should have clarified. The headunit has both left and right outputs for the front channel but theres only one set of them. The amp has two sets of left and right inputs, one set for the front and one set for rear. Unless I'm just confused on where to position the y splitter.
My cadence 4 channel has a switch on it that allows me to use one set of rca's rather than the traditional 2 sets for all 4 channels maybe other amplifiers use the same technology.
^^ depends if you have them split behind the deck or if you have them split at the amp. split at the amp is a lot easier and then you'll only need to run one set of rca's to the rear of the car
It is Opel (Vauxhall) Astra J 2011 model, I change the HU to Kirinavi 10 inch screen. The factory speakers are Infinity and would have come with a...
571
Okay, I'll bite. If you're going to get rear speakers, get the same ones (model type, doesn't have to be the same size) that you have up front...
I would keep the amp you have and keep the components. Place the components in some universal door pods, and look at getting a powered SAS 8"...
13
A 6 channel and a single sub amp would be my choice. Or a 2ch, 4ch and a sub amp. You don't need 2 channels for subs.
890
You can wire those subs up @8 ohms if they are both SVC4 ohm subs,and that amp will run fine after being tuned properly...
4
KilluminatiDre
KilluminatiDre
Japan
Side Show
just call me KeV
    Apr 27, 2024
just call me KeV
    Apr 27, 2024
Latest topics
