blazinb2000
Okay I have made a diagram to show the equipment and to help describe my problem. The problem is that today when I started my truck the sub never started playing. I checked the subwoofer amp and it was not on. I made sure all of the wires were hooked up and then thought to check the fuses. Well the fuse is blown in the zx250.2 amp. Not sure why it happened? Setup has been wired up in my truck and working fine for nearly 3 months. It is mounted securely so it didn't move around or hit anything and I don't think any wires touched each other. My question is should I just try and replace the fuse and see if it fixes it or is there something else wrong that will need more than just a replaced fuse? Never had any problems with any of my amps so I am unsure about diagnosing amp problems.
