Need help with amp problem please
Akshay
10
UK
Hi I have 2 amps being run from my head unit. The one for the subwoofer is ok as the sub is powering up and working. But the 4 channel amp has stopped working for some reason. I've had to remove a lot of rear trim to gain access to it but can't see anything obvious. There is power to the amp, there remote lead is powering up (live with tester) but the light on the amp is not coming on and so the speakers not working.
I have just tried with a different amp and the same thing is happening. Both the 12v and remote connections have power but the amp light is not on and no resulting sound. Don't know why the sub amp is working though.
The head unit has not been touched and the RCA's are all intact.
What else could be the problem as the car is in bits right now.
Thanks in advance.
Hi the fuses are all fine. I checked and I'm getting 12V at the power source and 10V at the remote wire. Just hooked up my subwoofer amp to the RCA's and speaker wires and the sound was working again. But when I used the 4 channel amp it wasn't working again.
I have re-checked the earth and that is fine.
But, and here is the but, I used my spare 4 channel amp, hooked up the power, earth and remote, and the front RCA's and speaker connectors. Replaced the fuse by the battery fused supply and the amp started smoking!! //content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif :eek: //content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif
I have no idea what caused that but the amp is bought as a used model off ebay. Could there be something seriously wrong here? I've never seen smoke from any amp before.
thats no ****^^^
check all of the fuses.. and possibly upgrade to a higher resistance fuse.. and check the grounds. as well as all of your other connections. its possible that the remote wire could be grounding its self out, causing the amp to not work right
Something is grounding itself out or you had 2 bad amps and when u get a good one hooked up it will work. Sometimes a amp will fry even a output and it will still turn on and play. Sounds like you were testing it with a bad amp and as you were trying to give it power it burned up and smoked. Plus I think your remote should be 12 volts not 10. Your amp looks for a 12 volt signal and if it sees a 10 volt signal it might not turn on : /. My 2 cents
I have now taken out the sub (was planning to do that anyway to free up space in the boot) and am using that amp to power my front speakers which are now working fine. The amp is powering up fine with the remote lead running at 10V but not sure why both 4-channel amps were bad.
As a result I now have no rear sound so wondering if a cheap 2 channel amp will sort the problem or if I'll be back at sqaure one!
The remote lead runs all the way to the stereo and nothing has been distubred recently to cause it to short out anyway. Strange huh?
Got it working in the end, when I tried the Infinitiy amp again it all seemed fine, even after smoking the initial time. I think it may have been down to bad earth because before with the previous amp I needed a GLI to eliminate alternator noise. Now the noise has gone. //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
Hi guys I now have the amp cutting out intermittently so all sound stops. Is this down to a damaged amp (was smoking before but ran fine afterwards) or is it a power supply/earth problem?
something has to be shorting out, preferably the remote wire... try taking a piece of 18 gauge wire roughly 2 inches long, and touch the remote and 12v. it the amps stays on then its something with the remote wire
Akshay
Akshay
UK
tommydh
