LED light strips
dragonware
Hey new project
I would like to install footwell LED strips
id like it to function just as my dome light,
On when the door opens, fades when door closes
A switch to turn on and off while the doors are closed or while driving
Basically exactly as the dome light functions
Ford focus 2008.
I have found the Fuse that controls the dome light. its a mini mini version of a 5amp blade fuse in the fuse box, hard to add a fuse tap any suggestions ?
Question :
Would I need to tap into that fuse or can i find a wire n splice into that ?
Should I add a fuse for my new LEDs what amp 2amp, 10 amp ?
i can connect it to the dome light fuse/wiring and it will work find but how do I get the switch to work ?
I have an illuminated Latching type 5 pin switch
NC
N0
C1
Thanks Khalid
I did mine but didnt do any fancy fading, just lights up when head light turns on and the ones on the side of the seat turns on when engine turns on, i will change it to all turn on when the engines is on, see pics
dude ebay strips will get the job done, you can get 15 foot strips for under 10$
yup I already got my roll of LEDs
My question was my current dome lights when the doors are closed there is a switch that I can turn them on while driving
So if I wire my LEDs to the fuse that controls the dome all well and good doors open on, doors closed dim/off
HOW do I wire an illuminated 5pin Switch to turn them on and off while driving ?
Also on the drivers side there is not many places to hide the LEd strip that it wont be seen
Pins are +, N0, NC, C1 & -
dragonware
dragonware
Canada Toronto
tommydh
