Need help with amp and sub combo.
kurt00
Hey i am having a few problems working out which amp and sub combo will work together and im begining to confuse myself. This is my first install so help me out.
I am looking a getting 2 x KICKER 12inch L7 Subwoofers 2 ohms and im trying to figure out what amp to run them on. I was thinking a mono block and having the Voice coils wired in series and speakers wired in parallel giving me a 2 ohm load. Just wondering if the amp im getting will work fine and if there is anything else i need to know.
Amp Specs
• 1000WRMS @ 1 ohm mono 14.4V
• 600WRMS @ 2 ohms mono 14.4V
• 1800WRMS @ 2 ohm linkable, dual mono 14.4V
• Low pass filter: 30 - 250Hz
• Bass boost: 0 - 12dB
• Phase shift: 0 -180°
Subwoofer Specifications
• Subwoofer Size 12"
• Dual Voice Coil Yes
• Impedance 2 ohms
• Peak Power Handling 1200 watts
• RMS Power Handling 600 watts
• Sensitivity 87.9 dB
• Frequency Response 20 - 100 Hz
Any help would be greatly appreciated.
kurt00
kurt00
Australia
MisterGrubbs
michigan born
    May 14, 2026
michigan born
    May 14, 2026
