Need help with a "Big Brand" choice
Okay, she wants the Infinity 12s. I've been trying to plug these numbers in to WinISD but it's telling me a 2.6 cu ft. box tuned to 24hz. I'm sort of a novice at this, but is that right? Infinity says 2 cu ft. tuned to 32hz. But they also say a 4x10" round port and that doesn't exactly come out to 32hz either.
THIELE-SMALL PARAMETERS
SENSITIVITY (2.83V @ 1M):93db
DIAMETER: 12" (300MM)
NOMINAL IMPEDANCE: 4 OHMS
VOICE COIL DCRESISTANCE: REVC (OHMS) . . . . . . 3.59
VOICE COIL INDUCTANCE @ 1KHZ: LEVC (MH) . . . . . . . 2.89
DRIVER RADIATING AREA: SD (IN2) . . . . . . . . 82.30
SD (M2) . . . . . . . 531.00
MOTOR FORCE FACTOR: BL ™ . . . . . . . . 16.90
COMPLIANCE VOLUME: VAS (FT3) . . . . . . . . 2.92
VAS (LITERS) . . . . . 82.96
SUSPENSION COMPLIANCE: CMS (μM/N) . . . . 206.00
MOVING MASS, AIR LOAD: MMS (GRAMS). . . . 222.00
MOVING MASS, DIAPHRAGM: MMD (GRAMS) . . . 214.00
FREE-AIR RESONANCE: FS (HZ) . . . . . . . . 23.50
MECHANICAL Q: QMS . . . . . . . . . . . 6.99
ELECTRICAL Q: QES . . . . . . . . . . . 0.41
TOTAL Q: QTS . . . . . . . . . . . . 0.39
MAGNETIC-GAP HEIGHT: HAG (IN) . . . . . . . . 0.314
HAG (MM) . . . . . . . . 8.00
VC (IN) .. . . . . . . . . 1.34
HVC (MM) . . . . . . . . . . 34
XMAX (MM) . . . . . . 13.00
Ah the Infinity Reference 12s brings me back to my second set of subs I ever owned....good memories. She'll be happy with them they can hold a little more power than they are rated and they are clean lows-highs. I'd tune them to 32hz
Yeah, Was thinking 32-33hz, but volume?
sorry at work can't do calculator right now, I imagine about 2ft^3 is about right, they will be clean they just don't get very low. tight bass though.
Well, she's into rock, alternative, country, so they will probably will suit her fine.
BreakinTHEbank
BreakinTHEbank
Oz
BreakinTHEbank
