need help wiring system
Im guessing that the amp is a 4 channel? If so (I dont know if this is the best way) i'd bridge the amp to 2 channels, then wire the subs to 4 ohm and hook a sub to each channel.
^ If it is an 850.4 then it is a 4 channel, and this is how you should do it, as posted above
VC's on the subs in series for a 4 ohm load, and bridge channels 1+2 to 1 sub, 3+4 to the second.
Negative, you'll get all of the power of 2 channels to one sub, and all of the power of the other two channels to the other
You'll get full power out of it
Says it's 50x4 at 4ohm, 100x4 at 2ohms, bridged it would be 200x2, so you'd get 200w per sub, theoretically speaking
miked_mad
buick member
miked_mad
h-town,tx
93 saturn sl2
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
