volume and tuning
knotslck
i couldn't get any replies in box and fiberglass help. i ordering two of the 05's comp vrs. im powering them with a da 1500d. i want mostly spl out of this system. any suggestions for volume and tuning of the box? also would a single chamber box be ok for two subs? any suggestions appretiated.
i have plenty of room. it's going in a vw jetta. they have huge trunks. right now i have one of the older comp vrs in a 2.25^3ft box tuned to 38hz. plenty of room left over. so a about 4 cuft net should be good tuned to 35hz? will a single chamber box be fine for these subs. kickers prefab box for these is single chamber correct but it doesn't look 4cuft either well prefab normally are smaller.
ht eprefeb is a good street ebater, but I would do a dual port chamber box, max 4.0 internal. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
what would i be losing buy doing a single chamber ported box. this is a lot easier for me to design. i could go with the dual but not if there is not a real big difference. i guess it is easier on the woofer and safer using the dual chamber box? i don't know.
4ft^3 internal. After driver and port displacement the box will be around 5ft^3.
A single chamber enclosure would put the drivers at risk if one were to fail. The other would be in a box larger than it can handle.
Also by using a dual chamber box, bracing is accomplished much easier.
knotslck
knotslck
who cares?
tRiGgEr
