Need help wiring system up
It's not basically a signal wire, it is a signal wire. It's just a low current wire that tells the amp whether or not that HU is on. You could probably put your tongue on the wire and not feel anything.
(If you do try that, don't blame me if it does shock the ish out of you.)
It's not basically a signal wire, it is a signal wire. It's just a low current wire that tells the amp whether or not that HU is on. You could probably put your tongue on the wire and not feel anything.(If you do try that, don't blame me if it does shock the ish out of you.)
12 volts on the tongue is NOT going to be pleasant! //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
TILCARRA
TILCARRA
Bokey!
DidUHearThat?
