need help wiring subs
jakel
i got 2 10" infinity reference series subs
i have been reading and searching about the ohms but i dont understand it so what is the best way to wire these up...and i pic wouldt hurt if you guys dont mind
this is what i think the way it should be wired up but correct me if im wrong.
but i think this one will work the best.................
Subwoofer Size: 10"
Impedance: Dual 4 ohms
Dual Voice Coil: Yes
Peak Power Handling: 1000 watts
RMS Power Handling: 250 watts
and a sony xplod 1200 watt amp
MOSFET Power Supply & Output Stage
• Maximum Output Power:
2 Ch x 400W at 4 ohm
1 Ch x l200W at 4 ohm
2 Ch x 600W at 2 ohm
• Rated Output Power:
2 Ch x 200W at 4 ohm (0.1% THD)
1 Ch x 500W at 4 ohm (0.15% THD)
2 Ch x 250W at 2 ohm (0.15%THD)
Well i have 2 RF P312D4 subs and there are dual 4ohms and im wiring them up to a 1 ohm load on my 2 ch amp, but im getting a mono soon, but i believe the wiring to a 2ohm will work the best for ur subs and if u want u can always switch the wiring around and try both 2 or 4 ohm loads and see what ones works best and look at the RMS for both 2 and 4 ohm on ur amp
so do i wire it up like the second one to one channel on the amp?
or can i do both subs like this to both channels of the amp
this ohms stuff is confusing.....
jakel
jakel
san antonio, tx
lilhomieb07
michigan born
    May 14, 2026
michigan born
    May 14, 2026
