Need help wiring equalizer
  • 2
Dylanx93
Hey I’m trying to install a audiopipe equalizer. The equalizer has sub outs front and rear outs main and aux in. My head unit has sub outs front and rear outs. I’m wiring a set of rcas from the front pres to the main in on the equalizer. Then the front and rear out on the equalizer to my 4 channel amp.that all works fine. It’s when I run the rcas from the subwoofer out on the equalizer to the monoblock I get no signal. I need help
Try again on the attachments/pictures. They didn't load. Not exactly sure on the wiring, but you can buy an adapter harness that goes from your...
No not in this situation.PM sent for proper use of the Y splitters for this situation
34
5K
Sure, 600 volts, yep. If you’re trying to launch the subwoofer cones to the moon! And, that’s if they don’t just vaporize first!
34
4K
Is that 1000w max? Don't expect to be able to bridge a 1000w amp at 2 ohms and get 500w x 2ch. I'm pretty sure you can't with that amp, for...
519
Dylanx93
Dylanx93
Indiana
Dylanx93
DEW123
    May 7, 2024
DEW123
    May 7, 2024
