Need help wiring 2 alpine swr-10d2 to an autotek 4050.1
Im trying to figure out the best way to wire 2 alpine swr -10d2 to an autotek 4050.1 amp. The amp is 1,2 and 4ohm stabe. It also has two sets of speaker out puts. The amp gives me 2000 rms @2ohms 1000 rms @4ohms. How can I wire my subs so that the amp sees a 2ohm load if possible. Im a noob lol
I just looked up that amp and you can't safely run it bridged at 2 ohms. Series each sub for a 4 ohm load and use the left/right speaker outs to run them at 4 ohms. To series, run the + from the amp to the + of vc1, jump the - of vc1 to the + of vc2, then the - of vc2 goes back to the amp. Switch the amp to the 2 channel setting.
Yep im totally lost now lol..so if I cant safely bridge it at two ohms to give me 2000rms then running it at 4ohm will only give me 1000rms total for both subs..***** because subs can handle 1000rms a piece. ****
connect speaker wire or jumper from 1 positive terminal to 1 negative terminal on each sub. Then connect the remaining positive terminal to the positive terminal on the amp. negative to negative. Do this for both subs. You only have a choice of 2 ohms or .5 ohms wiring and .5 ohms on an autotek is a fire hazard. You'll still have enough power to make them play but its not gonna push them hard unless you get another amp and run one for each or strap them.
Just to let you know, with a 90 amp fusing on that amp, your only gonna see around 900-1200 rms at 1 ohm so your subs will probably only get 300-350 actual watts each at 2 ohms. That amp has bloated power ratings.
Hey jeff thats exactly how I have them hooked up right now and thought I did something wrong does feel like its about 300 rms coming out the subs. Not hitting hard at all. Dang looks like I need another amp any recommendations
tymewilltell
Nashville tn.
Jeffdachef
