Need Help Tuning First Sub Enclosuere
HI Im building a subwoofer box and need help determining port length.
The Box is 2.188 Ft^3 and will have 2 round 3 inch PVC port.
The ports will stick out of the box 5 1/4 inches
I want to tune it tune 32Hz (is this good for rap and EDM?)
My question is A port calculator website gave me a port length of 14.81 inches
Does this include the 5 1/4 inches that extrude?
Is the 14.81 inches for each port or would each be half of that?
I'm using a 45 degree elbow how do i calculate the volume of that?
Thanks so much
your box is 2.18 gross probably but NET the actual usable air space for the sub is 1.57^3 then you need to account for sub displacement and port displacement... i hope your putting an 8 in this box or pushing the limits of a 10
nope none of that was included in your calculations, i used the specs you got on the sheet and this is what i got
your sub is recommended in a ported enclosure 2^3 after port and sub displacement
and i used this for the port length
Products Menu
what kind of vehicle is this for? a truck?
The dimensions giver we're from the inside not outside.
Anyways I have just finished building the box and took actual inside dimensions not calculated ones I'll include in pics
with these measurements I calculated a 15.35 inch port length now.
Since I need 2 it's a total length of 30.7 inches and using a port volume calculator I got the volume of the ports to be 217.0051 in^3
I went back and imputed all the data and added .07ft^3 for driver displacement (estimate infinity doesn't give displacement specs)
All together that gives me a volume of 1.996ft^3 which is perfect because infinity recommends 2ft^3
Is my math correct?
Rdannyr
Rdannyr
Duarte California
C1500martin
