Need help sub turns off
Webman33569
Ok here is the problem i am having if someone can please help me out.
Everytime i turn up the volume past 24 or so depending on the bass setting the amp does into same mode. I called Alpine they told me to check the wiring and use a multimeter on the voice coils which i did andc everything was good. What i am thinking is that the voltage might be dropping to much and when it does the amp goes into safe mode.
I have not done anything with the power yet im still tring to decide if i need a second battery of a large cap.
This is the gear i have.
1 Alpine PDX 1.1000
1 Alpine PDX 4.100
1 Alpine 12 Type X Sub
Type X componets in front doors and type R 5x7 in rear deck
Oh this is in an 08 Mustang.
its got plenty of space to breath. The sub is a dual 4 ohm ran parralel so its at 2 ohms which is what the amp is rated at. But its kinda funny to me cause the other amp does not turn off but i do notice that the volume dropps a little on it though. Will a seconf battery and the big 3 be enough im onlyh running about 1400 watts rms total.
Webman33569
Webman33569
Ocean Side, CA
dafobbishon3
