Need Help Setup 145-155db (NewInTown)
KenVGOD
I need real help guys. im not familiar with brands in the US. I dont know the goods and bads also. btw I just moved in. im from the philippines who migrated in the US specifically in NewYork Queens. i heard some good brands like Sundowns and also Orion HCCAs
I want a setup that is going to hit 145-155dbs and it is going to be my daily driven car. i have a Hyundai Tucson 2012. I want a Loud and Clear Setup that even if the bass is so loud it wont cover my mids. i also dont want to sacrifice my backseat. so ill be only using my trunk compartment and upgrade my doorpads if necessary. spending for about 5000-6000$
well since you are in the trunk you might do 1 ****** 15. like the SSA Zcon 15 or a pair of xcon 12s or a pair of BL 12s. chances are you will need a upgraded alt..
The trunk of a Hyundai Tucson 2012 is quite huge. i want a custom box fitted on the back the looks clean and cool. i want a pair of 15s or a pair of 12s thats gonna hit 145-155dbs. how much will upgrading or adding my alt cost?
A 145db can be done with a pair of Sundown SA 12s and a cab1600.1 amp that's like $700... if you want 155db you need 2 15s and about 20,000watts,dual alts, 8 g31 batts. And looking at like 5grand.
Having 155db sounds alot of work and considering 8 battery sounds mesy AF. Can a 3000$ setup hit 150db?
I have acouple friends with 150-152db trunk cars
150db two zv4 12s on ct 7k clamping like 3-4K out of it
151db two zv4 12s on a twisted sounds 8.5k
152.8db two 15s on 10k
Each setup has a $500 dollar alt and like $800 worth of battery's. And if your starting from scratch ad in wire,deadened, speakers and 4ch amp etc... it will get pricy fast.
I have acouple friends with 150-152db trunk cars 150db two zv4 12s on ct 7k clamping like 3-4K out of it
Im starting from scratch. This setup going to be my 1st in the US. ill guess ill get my alt, deadening and some batterys ready before i purchase the subs and amps im using. This gonna be pricy af
Yea most of us started out with pioneer 12s or kicker 12s and traded up to bigger and better things over the years.. it cost to much to do a full build all at once.
I started with pioneer champ series here in the philippines.
I think ill be going with sundowns already but nöt the ezpensive ones
That's a load of ****. Maybe in a hyundai tuscan but I did a 155.4 sealed with 2 18's, 10k clamped, 800a worth of alt and 2 d3100's. Didn't cost me anywhere near $5k
i think for starters a good 3500 and a good efficient pair of 12s in a big box ill get you high 140s. 8kw to hit 150 please. a good 4kw and the rght tune 150 with a pair of 12s ain't too hard. it wont be a excellent daily but it will slam on a good deal of tracks. measure up your trunk and let us know. ill be glad to help you out i assure you with something like the 3600 i have for sale and a pair of BL 12s in 4.25 cubes will knock you head off. i have 4.25 net with 56in^ of port area in my trunk and its a midside 4 door.. granted in not hitting 148 its mid 140s and drops fo 24hz and play well into the midbass with around a 6db octave slop starting at 50 so 100 hz still hits pretty **** hard. if i tweaked it for the meter i know i could knock on 150s door in the trunk..
Alternators, wire, lugs, head unit, speakers, deadener,4ch amp, tweeters, volt meter, rcas, subs, box, sub amp, speaker wire etc.... that will add up fast
KenVGOD
KenVGOD
New York
disturbed471985
