Need Help Really Bad!!
will the hifonics titan 750 mono amp be goo to run with this sub? its rated for 750 RMS and i found a sweet deal on one.. will this be good? or should i just get the kicker 750?
why are you raising the bs flag? the amp that i have plugged in right now is ****ed and is nor fonctioning properly.. i mean sure if i turn the gain all the way its retarded and sounds like crap. I just need help on finding a relitevly cheap but good amp.. But i dunno which one is gonna sound better
How about turning the gain down and see if the amp works correctly.
i did that too man. the amp is rated for 260 rms and the sub is rated 600 rms .. no matter what i do with the gains.. whenever i start to turn up the volume.. the amp shuts off the the blue light at the top starts to flash and you can here the amp clicking and turnign on and off.. and at other times. .the amp will stay on but the sub wont be working... :S
after a about 10 minutes of playing the amp gets insanly hot
Is it wired correctly?
Turning the gains up to try and get 600wrms out of a 250wrms amp is NOT going to happen.
yes. everything is wired correctly. I just think the amp itself is on it's last legs personaly. It's a pretty old amp. atleast it looks old as shit. Will the hifonics do me justice?
What is the input voltage? Head unit or eq using 4v or better? Get ahold of a meter and do some measuring.
My gains are only at ~20% with a 2v preout //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
OP: Are your "normal" speakers run off the headunit?
how do i figure out the input voltage? what to i put the meter to. i have a meter.. just have no clue about this stuff
First measure the resistance of the subwoofer. put the meter on Ohms setting and touch both wires with the leads of the meter. Your amp likes a 4ohm mono load. that will tell where you are with the load on the amp
snoogy17
snoogy17
canada
snoogy17
