need help! please
TXSoundwaves
I just recently wanted to try out some new gear I have had sitting around. A jblgto1201.1 (for right now). 2 12" konaki 12ao7(1200rms dual 1ohm) in 4cf @36hz and yellowtop optima. Now the problem is it seems like the back bat isn't getting enough power because when I turn it up the bass will stop and then come back on but the amp stays on the whole time. Any suggestions? Would the big three help?
Are you sure the amp isn't going into protect?
If the amp is staying on but the bass is cutting out, as ecrack mentioned you are probably sending the amp into protection. Either because of big voltage drops, or possibly because your gain is too high.
TXSoundwaves
TXSoundwaves
Texas City, TX
TXSoundwaves
BP1Fanatic
    May 14, 2026
BP1Fanatic
    May 14, 2026
