Need help on a box build for a 15 inch kove armageddon z series sub
Jason19
alright so my buddy gave me a brand new kove armageddon z series sub. The sub is a 15 inch and i need some help on what kinda box this thing needs. I wanna put it in my saturn and run about 1000 watts rms to it here is all the info I could find on it.
Specifications: *Power handling: 1050 watts RMS *VCdia: 3" *Le: 2.8 mH *Nominal impedance: 4 ohms per coil *Re: 3.0 ohms per coil *Frequency response: 20-250 Hz. *Magnet weight: 192 oz. *Fs: 37 Hz *SPL: 90 dB 2.83V/1m *Vas: 2.63 cu. ft. *Qes: 0.53 *Qts: 0.48 *Xmax: 20mm *Manufacturer model number: Z15D *Dimensions: Overall Diameter: 15-1/2", Cutout Diameter: 13-7/8", Mounting Depth: 7-1/2", Magnet Diameter: 7-3/4", Magnet Height: 3"
any help would be great thanks.
That'd be a great sealed box sub if the fs were lower, but you'd be better off with a ported box to get the low-end you need. Going off of the t/s listed, like any other mid qts woofer without a low fs, it's going to want a larger sized box and lower tuning. WinISD is showing me 5.5ft^3 tuned to 30hz for a "flat" box, but even something like 4ft^3 with a 32hz tuning looks pretty decent.
Jason19
Jason19
Kenosha Wisconson
pro-rabbit
