Need help installing stereo to 1996 caddy deville
Most likely someone blew the constant wire fuse, couldn't figure it out, and ran a new wire instead. If your head unit just won't power up, check all your vehicle fuses. I wouldn't use the other wire except as a last resort. Whether you use it or not, check at the battery to see if it's fused; and if it isn't, disconnect it from the battery.
suave89
suave89
Placentia, California
KaeZoo
