Need help finding an amp for my subs...
Numb1zero
Hey everyone. Im looking for a new amp. I ruined my last one because i didn't understand its limitations.
I have two pioneer "1500w" 12s in a sealed box.
The subs are 4ohm each and rms at 400w.
I think i need either a 2 channel amp that provides ~400w at 4ohms or a mono channel amp that'll do 800w rms @ 2ohms.
Problem is, i can't seem to find anything that matches what I'm looking for for less than about $600 which is more than I'd like to spend at the moment.
Can anyone recommend an amp that'll do these subs some decency for around $200?
I also don't know how safe it is to underpower the subs (say an amp that does 300w rms per channel at 4 ohms)
Is this okay?
If so, same question - any recommendations?
Thanks so much guys!
You need an amp that does 1000 watts at 2 ohms mono $200 for that amp. Might be a stretch. Unless bought used I can get you close to that power for $200 tho
I had a feeling that might be the case. What did you have in mind that would be close? I don't mind spending more than $200 that was just the budget i have myself not knowing what id need,exactly.
Hey everyone. Im looking for a new amp. I ruined my last one because i didn't understand its limitations. I have two pioneer "1500w" 12s in a sealed box.
Is this okay?
Thanks a lot. iPhone charging. Wow. No cigarette lighters now.
35
6K
No 10" sub is going to get you more vocal.
580
696
947
Numb1zero
Numb1zero
Nashville
i2ain2thunder
    May 12, 2024
Brendon Jenness
    May 11, 2024
