Need help deciding system to choose
I don't have a 500.1 I have a Hifonics brz2100.1 and price isn't really a problem just want something that will last and bump while still sounding better then the l7s or should I just go with a sealed box for those?
In that case run a Fi Q 10 or 12" fully loaded Daily option off your BRZ it will take it and love it. You could give HO Daytons probably 800w each in the right box which would save you some SQ from the BRZ since it won't be cranked up, also with the HO configurations with impedance you could just run them @ 2 ohms off that amp and power them and have a nice clean signal.
One of my friends sold me a new 13.5 W7 for 400 so that's what I have for now. Is it bad to have an amp that's 2100 rms with that sub? I guess my question is can amps or subs be damaged by underplaying them
They are good at the boom. Hard pounding lowend but lack at the upper notes. If you have a strong midbass setup they will blend fine. Buuut.. for...
13
11
518
627
https://youtube.com/@SaabUnleashed?si=-8qdxpYY0yGzrMsL Here you go. This guy does android head unit reviews. His reviews are how I found my...
7
891
If you want 5 channels of amplification you just need 5 channels of amplification. You can do this with 5 amps or 1, depends on budget and space...
Heat21
Heat21
Orlando, Florida
sacsking916
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
Latest topics
