Need help amp in protect mode will pay for info
  • 5
Ellsworthz
98' firebird, sleeper ftw
Re audio 1200.1 amp 12" skar sub installed for my buddy 3 months ago he called me and said the amp doesn't turn on randomly one night
Check power fuse under hood
Checked amp fuses
Opened up amp to check for something blown
Checked ground wire
Checked power wire
Checked remote amp lights up red when key on and car starts then goes off
Checked sub wiring it's still wired to 1ohm
Don't know what else to check and he's pissed please belp
Either the amp has fried from extreme clipping which you should also check the sub.
Or test with a new power wire to see if power is dropping or wire is bad.
There are some people real knowledgable about the inner machinations of amps here. Unfortunately I'm not one them.
Check that the voltage is correct with a DMM on the power wire and the remote wire. Also check that all of the wiring from the amp to the sub is in good shape and not shorted out. I've read some amp won't turn on if there's an output short.
667
While we're speculating, why not bump up your volume gain (no pun intended) for just a few dollars more (literally) and go with the 8" versions of...
972
* The fuse at the start of the cable needs to be equal to or greater than the fuse/load at the end of the run. * The cable needs to be capable of...
No not in this situation.PM sent for proper use of the Y splitters for this situation
34
5K
Ellsworthz
Ellsworthz
Decatur, Indiana
CrossoverOre
    May 18, 2024
    May 18, 2024
