need help !!a little confusion
mdd99
ok here i go..1st question.. do the wire gawge really make the sound different..4 gawge and 8 gawge...
2nd. question is how much amp. do you really need for one system to run.......i mean the alternator...such as 60, 80, 120,,do they make a different or the higher one are just for listenning to music when turning the engine off....if you put out 1000 watt...do you really need 120 alt instead of 60....
3th question is my car is honda accord 88 and my friend have accord 95 and is in an accident.. i was wondering if i can replace his alt with mine...is it good ..and will it help a bit..
How much current (Amperes) the system needs depends on the amplifier you use. For 1000 watts generally you'll need a 100 amp alternator or so.
Wire gage is also dependant on how much current is drawn. More amps needs thicker wire. For 2 reasons: safety and voltage loss. Wire too thin gets hot, melts insulation, shorts out, makes fires. Thin wire also has more voltage loss, so the amplifier doesn't get the input power it needs and can't make full output power. It all works together.
I have no clue about Hondas, can't answer that.
mdd99
mdd99
Los Angeles, CA
maylar
