Need Definitive Answer!!!
RomeoGAOC
CT
ive got my whole system pretty much all bought and ready to be installed, but im not sure if the whole thing will exceed my power capabilites. Heres my setup:
DHD power cruiser (80W x 2 @ 4 ohms)
Kicker kx200.2 (50W x 2 @ 4 ohms)
Kicker kx500.2 (250W x 2 @ 2 ohms)
What are my options here? Will I need to buy a higher output alternator? Battery? I def plan on doing the big 3 as well. Im going nuts here, I just want a yes or no answer, and i get both answers from a bunch of diff ppl!
big 3 should be fine you could also do an upgrade on your alt/bat to get more out of your equipment however in my car i have a stock 100 amp alt when i was running 4 8s off a 500 watt amp there was no draw whatsoever we were testing my alt to see what it acatually put out it registered at 100 amp then i turned on my system all the way up to and the alt stood strong just like when the system was off. im not sure how stong your stock alt is but if its around 100 amps then that wont be much of a draw on it especially when you do a big 3
RomeoGAOC
RomeoGAOC
CT
Bigrick31
michigan born
    May 14, 2026
michigan born
    May 14, 2026
