need box for GTO1204D
http://www.crutchfield.com/App/Product/Item/Main.aspx?i=109GT1204D&tp=111&tab=detailed_info
if someone could design a box for me that would kick ***.
-the box can not be any deeper than 10 inches
-the box can not be any wider than 41 inches.
this will be going in a mazda 3 hatch and i would like to use the cargo tray under the floor (hence the 10inch depth requirement) or else i would use one of the dimensions in the sticky.
i dont know if i should go ported or sealed. i listen to alot of rock and music with super fast double bass drum hits, if ported will mess up the tight drum hits i love so much i will go sealed. however if you recomend ported please design it useing the older tube port style because it requires less wood and is easier to make. thanks in advance.
classicaddict
classicaddict
aberdeen MD
classicaddict
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
